#42 | |
![]() ![]() lo que pasa que de algo hay que hablar,,,y va bien hablar cosas de estas, a mi me gustan,,,y ademas cada uno hace lo que quiere o puede con sus €.. ![]() pero lo que te he dicho, en el post anterior antes, no es broma,,veo que cada dia estoy mas carroza, y tenemos que aprobechar el momento, y no dejar pasar ni una,,lo que pasa que saco espiritu de donde no hay,,te lo puedes creer,,,otro si estubiera como yo no se lo que haria,,,pero no pasa nada,,si tiene que pasar algo pasara igual ![]() Olle no te pongas triste,si no no te explico nada mas ![]() tomarnos unas birritas,,solos no, con las Sras. ![]() |
#44 |
La nueva TMAX 500 (2008) al precio de 9300€, ya está disponible en Inglaterra.
Para más información, os pongo la versión en Inglés y una traducció suigeneris en español. La web es: http://www.yamaha-motor-europe.com The new TMAX is a pure expression of power and beauty, perfectly balanced. Every new feature speaks the language of performance and comfort, to give you an unique riding experience.What’s big on the new TMAX? The front wheel, to start with , has been increased to 15”and the front forks are larger in diameter, both providing improved stability. Furthermore, the fuel tank has been enlarged to 15 litres’ capacity. The new TMAX also provides more comfort, thanks to a new seat shape, new passenger handgrips, and a newly designed windscreen for better protection. Bigger the pleasure for your ears, thanks to a newly designed muffler that provides a sporty attitude. Then there are new front and rear body design, a new instrument panel and an additional storage compartment. You might now think - with so many additions - the new TMAX has put on some weight, right? Wrong! Thanks to its all-new CF die-cast aluminium frame, it is now 5 kg lighter!Surprised? Just wait to ride it! You’ll experience that the improved torque performance from the 4 valve, 499cc fuel injected engine is the best way to accelerate adrenaline into your system. The new TMAX will take you around the city, or to any other faraway destination with great comfort, fun and endless enthusiasm. La nueva TMAX es una expresión pura de la energía y de la belleza, balanceada perfectamente. Cada nueva característica habla la lengua del funcionamiento y de la comodidad, para darte una experiencia única del montar a caballo. ¿Cuál es grande en el TMAX nuevo? El de rueda delantera, comenzar con, se ha aumentado a 15” y las bifurcaciones delanteras son más grandes en el diámetro, ambos que proporcionan estabilidad mejorada. Además, el depósito de gasolina se ha agrandado a 15 litros' de capacidad. El TMAX nuevo también proporciona más comodidad, la agradece a una nueva forma del asiento, a asideros nuevos del pasajero, y a un parabrisas nuevamente diseñado por una protección mejor. Más grande el placer para tus oídos, agradece a un silenciador nuevamente diseñado que proporcione una actitud deportiva. Entonces hay nuevo diseño delantero y posterior del cuerpo, un tablero de instrumentos nuevo y un compartimiento adicional del almacenaje. ¿Puede ser que ahora pienses que - con así que muchas adiciones - el TMAX nuevo ha puesto encendido un cierto peso, la derecha? ¡Mal! ¡Agradece a su marco fundido a troquel los CF completamente nuevos del aluminio, él ahora es alumbrador de 5 kilogramos! ¿Sorprendido? ¡Espera justa para montarlo! Experimentarás que el funcionamiento mejorado del esfuerzo de torsión 4 de la válvula, motor inyectado combustible 499cc es la mejor manera acelera la adrenalina en tu sistema. El TMAX nuevo te llevará alrededor de la ciudad, o a cualquier otra destinación lejana con gran comodidad, la diversión y el entusiasmo sin fin. Saludos |
#49 |
yo lo tengo claro desde hace tiempo esa es la moto que quiero .lo unico que todavia no me deja dar el paso es ver el modelo 2008 que la verdad me gusta mucho ,alguien me dio ese consejo el de esperar y si no me gusta pues al del modelo 2007,pero tengo claro que cuando de el paso sera a tmax
#51 | |
#55 |
PIEDRAAAAAA VAAAAAAAAAAA!!!
Aprovechando este rinconcito unas preguntillas: - Por comparar, ¿que suelen beber vuestras Tmax? - Quien haya probado, ¿98 o 95? - En el marcador de gasolina, cuando baja dos segmentos se queda una forma rara de triángulo en la parte superior, que cuando baja otro segmento más se queda en mitad de la pantalla, ¿eso tiene alguna misión el estar allí? Primeras impresiones. De momento y hasta ahora llevo 800 y pico kms y de coña, una pasada en estabilidad, frenos, acabados, calidad general... muy buen bicho. Se nota aunque tenga más motor que la X que le pesa un pelín el culete, pero bueno, también es cierto que pesa. Descarto ponerle nada a corto / medio plazo (y casi que a largo) para que tenga más alegría, pero una pregunta que lanzo al aire, ¿se podría hacer algo para reducirle peso? Otra cosa más, hoy le he quitado la maleta y no se si alguno más la soleis gastar, pero al quitarla me he dado cuenta que el comportamiento se me antoja (por lo menos a mi) mucho mejor y eso que ya me gusta de por si. ¿Alguien está conmigo en esto? |
#56 | |
#60 |
En cuanto a lo de la gasolina, como ya comentó tmaxblue, yo utilizo la de 98 que he comprobado que estira algo más el tanque, cerca de los 230 km cuando con la de 95 llega a los 195 o 200 como mucho.
Lo del triangulito ese me he fijado pero lo miraré bien, porque yo creía que era la mitad de tanque. Pesar pesa, pero el motor la mueve de sobra (y eso que yo la tengo todavía limitada) y lo del culete no lo he notado, yo también paso por ahora de ponerle nada, como mínimo hasta que pase la garantía oficial. En cuanto a lo de la maleta, yo no llevo ni llevaré, pero de la otra moto que tuve, si que cambia el comportamiento. Yo incluso lo he notado entre lleno y vacio. Con los 6000km cumplidos puedo decir que la compra ha sido satisfactoria, es un buen bicho. Por cierto, para rebajar peso pues no se que decirte que se pueda quitar, mira tú que los japos de Yamaha le han metido chasis de aluminio y solo le han bajado 5 kilos, así que veo difícil la cosa. Cosas que se le podrían hacer, cúpula corta, guardabarros delantero más pequeño, recortar el guardabarros trasero y después piezas de carbono (pero a que precio ![]() ![]() |
